Two questions shift knob, and radio
Two questions shift ****, and radio
one how to remove the shift **** in an 04 automatic, there is a screw off ring, but the **** wont come off, two i got this car used, and the stock radio needs a code to use after the power is cut off. is there a way to get that code, because the radio wont work without it
RE: Two questions shift ****, and radio
Unscrew the ring until it comes off. The **** should come off pretty easy after that. I replace mine a while ago, so I don't remember the details, but I know it's not complicated. If you go to the dealership (a decent one), they should be able to get you the code if you can prove that you own the car. It took me almost a month, and trying 3 different dealerships before I found one that could figure it out. Hopefully you will have better luck.
jrsavoie
July 4th, 2011 6:18 PM
adamant
Silverado & Fullsize Pick-ups
February 15th, 2009 8:49 AM
Mcguinness
Intake, Forced Induction, & Exhaust
February 14th, 2008 7:00 PM
