Noises from suspension
Hey guys,
I have an 01 silverado witha 6in Fabtech lift. The guy who previoulsy owned the truck got the lift installed back in 03. When I go over speed bumps or enter in driveways there is a squeaking sound coming from the front left suspension. I know that sometimes you get sounds in the suspension from lifts....im aware of this....is there something I can do to get the squeaking to go away? Lube parts?? New bushings??
Thanks
Thanks
RE: Noises from suspension
I would just try spraying the A-arms with a little bit of lube, but first I would find all the grease fittings and grease them. If the squeaking is still there, lube a arm bushings. If the squeaking is still there. Look at your shocks for signs of leaking and such. Hope this helps.
Simon-Pierre Lacasse
Express & G-Series Vans
March 8th, 2014 7:18 PM
akabavah
Avalanche
October 10th, 2009 9:54 PM
