Suspension & Tire Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Got sleek low-pros or gnarly mudders? Step in and let's talk about 'em!
tires for gravel roads
Old January 9th, 2015, 11:59 PM
tript's Avatar
Default tires for gravel roads
Hey guys
I looking for some tires for my truck, and looking to get some input
I got 300 km of gravel go the nearest (tiny)city, of rough tire eating road.
looking for something AT, probably a harder tire got any ideas
thx,
Old February 23rd, 2016, 1:46 PM
josiemarie's Avatar
I have cooper ATPs on my pickup and they've been doing great on gravel so far. unfortunately all AT tires are gunna get eaten up by gravel quicker than normal. I'd recommend the coopers! They look relatively aggressive for not being a mud tire and everyone ive sold them too has liked them!
Old February 24th, 2016, 11:50 AM
SWHouston's Avatar
Gravel is probably the most destructive surfaces one can encounter.
Rather than give you a specific brand...
1: The more rubber you can put on the road the better,
ie: as closed/tight tread pattern as possible.
Street/HiWay treads are the most likely to have this.
2: The harder the rubber the better.
ie: High mileage tires usually have higher "shore hardness",
That 's the density of the rubber.
Now...
When you close the tread pattern, you're going to decrease the tire's ability to discharge water, therefore decreasing it's wet traction/control.
and...
Harder the rubber reduces the dry traction ability, and your stopping distance increases.
The two caveats above, don't present a severe difference in performance, specially to a driver that's aware of the tradeoffs.
Old March 29th, 2016, 10:35 PM
HelloTrucker's Avatar
If you drive on gravel roads a lot, tire wear will be an issue. you may want to check out tires like Grapplers, Goodyear Wrangler Silentarmor, Duratracs, General Grabber AT 2
Old March 30th, 2016, 2:09 PM
SWHouston's Avatar
What a great looking GSD, I bet it gives real good kisses
Old March 31st, 2016, 6:58 AM
extremeadventurer's Avatar
I recommend that you get Wrangler DuraTrac Tires.
Old April 18th, 2016, 4:56 AM
iluvchevy's Avatar
I would either get Bridgestone Dueler AT Revo or Duratracs. These tires can perform well on a gravel road.
Old January 1st, 2017, 6:21 AM
BobnChevy's Avatar
Go to tirerack.com and find comparable tires/vehicles.
dolphinsnum1fan
Silverado & Fullsize Pick-ups
July 1st, 2012 7:13 PM
offshore44
January 27th, 2012 1:51 PM
cupofchicken
December 16th, 2011 3:12 PM
BCZIGZAG
March 23rd, 2009 9:42 PM
Quick Reply: tires for gravel roads
