2007 tahoe:radio volume full
Hi,I have a 2007 Tahoe LT.I bought the car used and the volume as soon as I turn on the radio is stuck at full.I can see the volume display working but the volume is stuck at full.I took it to a technician he checked all the wirings,everything is ok.When he connects to a Tech 2...it says that there is no communication between the radio and the amp.plz help.
hrq318 Welcome to the forum...
Had you checked out the radio before and it worked or is this a surprise find...
It could be a bad radio or amp or it could be something simple...
I would first try disconnecting the battery for a few minutes and see if it resets itself...if not it might be time to pull the center console and try re-seating some of the connections....
Well that was going to be one of my other suggestions but when you said you took it to a tech with a tech2 programmer I assumed you had already been to the dealer and programming was tried....
but yes it is very possible the whole issue could be a programming refresh related...
I did not take the used amp i got from a salvaged tahoe to the tech 2 guy,i just plugged it in and the volume was the same.I will take it to the tech2 programmer tomorrow...
what do u suggest for the steering control?
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Hrq318,
Let us know how it goes after you take it back. Did you purchase some sort of warranty with the vehicle? If you would like to send me your VIN number and name I can also check with some of my sources and see if they have any information on it.
Breanne
Chevrolet Customer Service
Breanne
