2003 Suburban AC not cold in front but cold in back
My front AC is not cold but my rear AC is cold. Freon checked good. Compressor seems to cycle often not sure if that is normal?
NEVER ADD ANY SEALERS OR REFRIGERANT CONTAINING SEALERS !!!
oilcanhenry (October 11th, 2020)
May have a blend door actuator problem or a controller panel problem, but yes, post the basics first. The pressure gauges help to see what is going on inside the system. But the actuators are a known weak spot. Check out a you tube video or 4 to see what I am talking about.
Sample of the controller, since I have no idea which you have: https://www.rockauto.com/en/moreinfo...12198&jsn=1693
Sample of the actuator: https://www.rockauto.com/en/moreinfo...12198&jsn=1763
