07 tahoe 5.3L rough idle, anybody else has the same ?
When warmed up I can feel the engine not running smooth while in drive and idle. When in park, it's less noticeable. Slight vibration can be felt through the vehicle. Feels like misfire. I have been feeling this from the day I bought it. When I look under hood while it is running I can see the engine shaking. The salesman said "it's a big engine it is normal". I owned vehicles with "big" engines before and they ran smooth. My question is do I need to put on more miles on it because it just needs time to break in or is this possible problem that I should have service dept check? it has1200 miles now.
5.3L, not the flex fuel version. Manufactured Jan/06. I tried to find some info in older posts, but couldn't find anything. Thanks for any suggestions
RE: 07 tahoe 5.3L rough idle, anybody else has the same ?
know you said it is not flex fuel but i would look into where you get your fuel i have had this problem before not in my 07 but i came to find out that the place i got my fuel didnt have a clean record had to change the filters injectors etc
Thanks for response. The engine runs rough regardless of where I get gas. I do not go to same gas station. Typicaly I use Arco that I am using in my 02 Dodge Ram and never had problems. Occasionaly I may get Shell or 76. But hardly ever in same location. But I do know what dirty fuel can do.
+1 on the Techron, it should help cleaning the injectors. You can also try to put the Super Unleaded in your tank once. I use the Plus. Where do you live? If its cold then let the engine warm up a bit. I have had the same problem in my other truck, put some Techron in the system and no more. I probably used two bottles to make it more concentrated.
I notice a very very light vibration/rough idle on my 07 non flex fuel while sitting still and in park. At first I thought it was the base from from my stereo, but noticed the same occasional vibration when I turned the radio off. I am not too concerned about it yet, but I will have it checked out at my next oil change or service.
ORIGINAL: 07LS
The good thing is that if it is something serious it should be covered under warranty. Keep us posted.
Thanks for all responses. I live is S. California so no problem with cold. Yes it is freezing now 55F but that is just being spoiled.
With 1200 miles I would not think that there is too much buildup in the injector even if the fuel I am getting was not the best quality.
I will try to fill it up with Super and see if it makes any difference. Normaly I use regular 87 octane as they recommend.
There is no buildup on the injectors in 1200 miles. If it's running rough you need to get it in to a dealer for a diagnosis before you do some serious engine damage.
Do you think it could be more serious problem? I also noticed that the end of the exhaust tailpipe is very black and coated with ash kind of material.
Also my gas mileage is far different from the estimated so I don't know if all this has anything to do with the rough idle or not.
I called one dealer and they told me: If your check engine light is not on, don't be concerned.
