07 wiring diagram
RE: 07 wiring diagram
Posted: July22, 2006 at 10:17 PM - IP Logged
[hr]
Radio 12v
red/white
radio harness
Radio Ground
black
radio harness
Radio Ignition
(GMLAN Serial Data)
Radio Illumination
yellow (dimmer)
radio harness
Factory Amp Turn-on
same as power antenna wire
Power Antenna
white
radio harness
LF Speaker +/-
tan - gray
radio harness or amplifier
Notes: If equipped, the amplifier is under the rear of the center console.
At the amplifier, the left subwoofer wires are dk. blue/white (+) - lt. green/black (-). The right subwoofer wires are dk. green (+) - lt. blue/black (-).
RF Speaker +/-
lt. green - dk. green
LR Speaker +/-
brown - yellow
RR Speaker +/-
dk. blue - lt. blue
Interface Module:
Category:
Immobilizer Bypass
Required:
Yes
Type:
PASS-Key III+
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Standard on all models.
Smart Starter Kill Relays:
Relay Type:
Starter Relay
Engine compartment fusebox, Driver side
Part #: 6404A
12volts
red/white (2A)
ignition harness
Notes: For high current 12V, use red/black (60A) and red/black (60A) at the fuse box, black 40 pin plug, pins F1 and E3, or go to the battery.
Ignition
pink
ign harn or BCM, lt. grn plg, pin 14
Notes: The BCM (Body Control Module) is to the left of the steering column.
Parking Lights+
brown (L), brown (R)
underhood fuse box, blk 30 pin plug
Parking Lights-
lt. blue
switch or BCM, natural plug, pin 8
Headlight
white
switch or BCM, natural plug, pin 12
Trunk/Hatch Release
pink (glass), gray (gate)
BCM, pink plug, pins 24 and 13
Notes: Meter these wires while opening the liftglass or liftgate from the handle on the rear liftgate.
On vehicles with the power liftgate, use dk. green/white (-) at the switch in the overhead console.
Power Sliding Door
N/A
Speed Sense
yellow/black
ECM, black 73 pin plug, pin 57
Notes: The ECM (Engine Control Module) is in the front driver side of the engine compartment.
Wipers
gray
BCM, brown plug, pin 20
LF Window up/dn
dk. blue - brown
A
DDM, black 6 pin plug, pins 3 and 1
Notes: The DDM (Driver Door Module) is in the driver door.
RF Window up/dn
dk. blue - brown
A
PDM, black 6 pin plug, pins 3 and 1
Notes: The PDM (Passenger Door Module) is in the passenger door.
LR Window up/dn
dk. blue - brown
A
LR window switch in door, pins E, H
RR Window up/dn
dk. blue - brown
A
RR window switch in door, pins E, H
Sun Roof open/close
motor part of module
Sun Roof Limit/close
N/A
Memory Seat 1
orange
switch or DDM, blk 26 pin plg, pin 5
Notes: Memory seat 1 is positive trigger thru a 2260 ohm resistor. Memory seat 2 is positive trigger thru a 4260 ohm resistor.
Memory Seat 2
same as memory seat 1 wire
Memory Seat 3
N/A
I got this from www.the12volt.com website. Its for an 07 Tahoe so pretty much the same vehicle.
Shaun_95
Silverado & Fullsize Pick-ups
November 23rd, 2009 9:56 AM
