1995 Chevy Tahoe A/C - Chevrolet Forum - Chevy Enthusiasts Forums
Jimbo123's Avatar
July 8th, 2010, 1:34 PM   #1
I have a question, how much freon does a 95 Tahoe hold? I have 2lbs in it already but when it's 90 degree's out..the thing seems like it's not coming out cold enough. When it's 75-80 degree's out..it works fine. I've got it down to about 45 degree's inside..but would like to see if it can go colder by adding/removing freon?? I've replaced the compressor, evap, accumulator, flushed out the lines...
SabrToothSqrl's Avatar
July 8th, 2010, 2:09 PM   #2
none
The 1995 Tahoe contains no freon. I know, I used to have one.
http://en.wikipedia.org/wiki/1,1,1,2-Tetrafluoroethane
On something that old, i'd wager it's running fine...
Pressure is more important, add too much and it won't work :-/
Austin, Texas
July 8th, 2010, 9:14 PM   #3
The 95 probably has the R12 freon but could be R134 but regardless if its not getting cold enough when its hot you may want to check the condenser (front most radiator) for excessive debris or damaged fins, if you have added a tranny cooler to the front that could also impact it.
You really need to put a set of gauges on it to know if it has enough freon charge.
Austin, Texas
July 8th, 2010, 9:28 PM   #4
the fan clutch may be worth looking at too, if it is slipping too much you may be getting insufficient cooling....
KC, MO area
July 8th, 2010, 9:38 PM   #5
Jimbo123: Welcome to the forum.
To answer ur question, there should be a decal on the radiator support that tells how many pounds of R-134a it holds w/ & w/o rear A/C.
T5258's Avatar
New Bedford, MA
July 9th, 2010, 11:46 AM   #6
with rear A/C 4.0 lbs....with front only, 2.25 lbs...R134
KC, MO area
July 9th, 2010, 3:16 PM   #7
Another place to check for debris buildup, albeit much harder, is the evaporator.
Jimbo123's Avatar
July 10th, 2010, 10:25 AM   #8
Posted By: T5258 with rear A/C 4.0 lbs....with front only, 2.25 lbs...R134
Thanks T5258!
Perfect answer!
Jimbo123's Avatar
July 10th, 2010, 10:28 AM   #9
Posted By: 73shark Another place to check for debris buildup, albeit much harder, is the evaporator.
It's not the Evap, I just put that in a week ago, replaced the condenser, compressor, acculmulator, flushed the lines out...it's just that it didn't have enough freon. I'll add more later today.
Thanks for all the replies..everybody!
Tags
Sponsors
  • Ask a Question
    Get answers from community experts
What's your question?
Send
