Notices
2 wheel drive to 4 wheel drive and back
Old March 30th, 2014, 9:23 AM
Billy HC's Avatar
Question 2 wheel drive to 4 wheel drive and back
I did not get any paperwork with 99 Suburban. How do I go from 2 wheel drive to 4 wheel drive and back? I have the one with controls on the dash.
Old March 30th, 2014, 10:24 AM
Farmer Jon's Avatar
push the button.
Old January 24th, 2016, 8:19 AM
peicesr1's Avatar
Default awd
2003 chevy suburban 1500, service awd is always on. I have no awd at all where do I start. It feels like I have a big car!!!
Old January 24th, 2016, 10:14 AM
cleveland63b's Avatar
get the code(s)
Old January 24th, 2016, 3:25 PM
peicesr1's Avatar
No codes come up
Old January 25th, 2016, 11:22 AM
SWHouston's Avatar
That's true, all you have to do is push the button.
Engaging 4hi is usually no problem.
However, and mostly because of non/little use,
going into 4lo can be very slow, or it may not change at all.
Try above, and let me know if you can't get 4lo, if not then
I'll talk you through a procedure to possibly make that happen.
Old January 25th, 2016, 1:36 PM
if it has a message displayed there will be codes, most low end scanners only scan the ecm which may be why you're not getting any
Old January 25th, 2016, 9:11 PM
peicesr1's Avatar
I tried to shift in to 4lo and hi bit none worked. I also tried to engage while car wasn't turned all the way on... Please if you can walk me through it would be greatly appreciated during the blizzard that hit NYC 2 days ago...
Old January 25th, 2016, 9:12 PM
peicesr1's Avatar
I might have to take it to the dealer
Old January 25th, 2016, 9:35 PM
if theres a message for service 4x4/awd then the system is most likely disabled, can't help a whole lot through the computer without knowing what the codes are
Quick Reply: 2 wheel drive to 4 wheel drive and back
