2000 Tahoe Limited power locks
Old May 17th, 2010, 10:17 AM
snoski's Avatar
Default 2000 Tahoe Limited power locks
Driving to work today and all doors automatically locked and now I cannot unlock or lock with the door switches or keyfob. Can only do manually from inside or with door key. I pulled the fuse at location 13 at the drivers side location fuse block and it was ok. When I replaced it into the fuse block the doors locked again, and again nothing worked to unlock or lock the doors.
Can someone tell me the location of the door lock relay, as I feel this is the culprit here.
Thanks in advance for your help...
James
Old May 17th, 2010, 10:22 AM
welcome to the forum... I can't say for sure but I would take a guess they are in the power center under the hood, the cover should have a label for the relay layout...
Old May 17th, 2010, 11:55 AM
snoski's Avatar
Ok, I found it. The relays are in the same block as the fuses. One for the windows and the other for the locks, power seats, and rear hatch. I pulled the relay and reinstalled it, and it now works. Guess it had to reset or something.?.?.?
Old May 17th, 2010, 3:18 PM
the contacts could have gotten stuck....
Old May 18th, 2010, 2:19 PM
snoski: Welcome to the forum. Glad you got it fixed.
Old May 18th, 2010, 2:39 PM
WC4J
December 16th, 2010 11:33 AM
atis
April 12th, 2010 8:00 PM
MadMullen13
September 17th, 2007 1:07 PM
steveb2833
March 17th, 2006 4:30 PM
Quick Reply: 2000 Tahoe Limited power locks
