2001 suburban driver side floor wet
Hello
I have just had this suburban for 3 weeks now I have found yesterday that the driver side floor board is wet no clue where the water is coming from. I did get it washed the other day but I never saw any water come in.
Welcome to the forum,
The water could have come in from the car wash or be coming from the AC drain. Check under the vehicle on the passenger side and see if anything is blocking the AC drain tube, may want to poke up in it with a stiff wire...
if that is not it try flushing the windshield with water while someone is in side and see if any water is getting in....
x2
:chug:
thanks for the help I will check the ac tubes I have water in the back but on the passenger side and I believe that is where that is coming from, I did not think the drivers side front would have been the same because it is on the other side. I will check bothe rear and front then thanks guys.
maxxmusle
September 6th, 2008 5:50 PM
