Last edit by: IB Advertising
Browse all: 4WD
- Chevrolet Silverado 1999-2006 GMT800 How to Replace Transfer Case Oil
Step by step instructions for do-it-yourself repairs.
Browse all: 4WD
2001 tahoe leaking transfer case fluid
Hi
I just notice some dripping on the floor and on under carriage of 01 tahoe. Seems to be wet around the front u joint area. I just replaced the output shaft seal 3 months ago and that area is dry so that is ruled out. My buddy who is GM mechanic tells me to check fluid and take off fill plug in transfer case and see if it is over full. Said possible bad trans seal where it meets the transfer case. I see vent hose and it seems dry around that area too. The whole transfer case is bone dry. Any ideas ???
I would start by doing what your GM mechanic buddy suggested. Then if that doesn't prove to help, I would clean off the area where the leak appears to be coming from with brake degreaser and watch for new signs of leakage.
transfer case fluid leak
So i checked my trans fluid and it seems good. Next step is to check my transfer case fluid. Someone told me my yoke could be warped and its seeping out slowly near the u joint. Any other input or similar issues anyone has had would be awesome
wow ok getting down to buisness I see with that transfer case.
hey buddy
All of the talking among your buddy who says hes a mechanic and all of the talk on here is about as useless as **** on a boar.
Short and simple
You need to get under that turd and pull the transfer case and replace the seals brosive.
Still get a chuckle about peeps that have a motor issuse and they resolve it by chatting online with other soft hands who have never even used a pair of pliers.
Get under that thing and lay on the ground at the car wash and pressure wash that thing, then drive it home and pull that Transfer case and replace the seals bro.
Man up
Short and simple
Man up
yoke warper
Brother who ever told you the yoke could be warped is possibly warped them self.
If You have ever seen a yoke and you understand the forces acting on a yoke you will know that is a idiotic idea, warped yoke.
Just not possible unless you are pulling 80,000 lbs and have a semi truck diesel engine that is running 22 hours a day in the mountains, then I could believe that a factory 2001 Tahoe 4x4 yoke could possibly be warped otherwise I would never again speak to the genius who told you that the yoke could be warped.
lol raweggfart you are dick.that what this forum is made for people question.to your question the np246 transfer case have problem's where the pump rub a hole in the case.check that too.far more why make him pull the tcase and cause him more work?if he doesnt have to.check all the area before you pull the tcase like this dumbass stated!!!
I don't believe pump rub is his problem, but he should look it up on youtube "chevy pump rub". Clean off the t-case with degreaser and check for fresh oil. Also check the t-case fluid level.
Chevy_Joe
Silverado & Fullsize Pick-ups
February 26th, 2012 2:22 PM
