Notices
Old July 22nd, 2015, 11:44 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior
Print Wikipost
2001 Tahoe oil leak
Old January 30th, 2011, 1:56 PM
  #51
KeithKman's Avatar
Originally Posted by 73shark
Thanks for the feedback. I take it that you got the fuel pump replaced?
Sure did. Got raped by the dealer though. I was out of town so I had no choice. I could have easily have done it if the fuel pump went out if I was home.
Old September 1st, 2011, 11:39 AM
  #52
fuzzo's Avatar
Default Engine oil losses
Chevrolets with the 5.7 Vortec engine can and do lose oil due to leaking intake manifold gaskets. I've owned 3 and all needed replacement at some time. The gasket design allows oil vapor to be drawn from the lifter valley into the engine's cylinders on each intake stroke once the gasket integrity is gone. The leak can be a little or a lot. The leak also causes lean mixture problems leading to poor fuel economy. Replacement with quality gaskets has always cured both issues for me. Hope this helps.
Old September 1st, 2011, 11:44 AM
  #53
fuzzo thanks for the input and welcome to the forum
Old September 1st, 2011, 11:45 AM
  #54
fuzzo's Avatar
GM Vortec engines are prone to intake manifold gasket leaks, allowing oil vapor to be drawn into cylinders with each intake stroke. Also causes lean cylinder mixtures and poor fuel economy. Replace with quality gaskets to cure both issues.
Old October 17th, 2011, 6:56 PM
  #55
bacon7's Avatar
Like alot of others I am also having oil leak problems on my 2001 gmc sierra 5.3 1500. I have replaced the rear main seal and rear cover seal and still having oil leaks problems. Some of the people here say they have replaced the pan gasket and that fixes the problem in some cases. Does anyone know what the real issue is and how to fix it. thanks
Old October 18th, 2011, 9:28 AM
  #56
KeithKman's Avatar
I can't tell you how frustrated I was when my Tahoe was leaking oil. I had the rear main seal, rear cover seal, oil cooler block-off, and oil pan drain plug replaced and it still was leaking.
From the get go I told the shop that did the work I was pretty sure it was the oil pan gasket but they always insisted that was NOT it. They finally changed the oil pan gasket and my Tahoe hasn't leaked since. I have put on over 10k miles since then. I hope I didn't just jinx myself.
Old October 19th, 2011, 6:26 AM
  #57
kbourne's Avatar
For my 6.0L Suburban it was the rear main seal. But along the way I replaced valve cover gaskets, transmission cooler gasket, oil pan gasket (this is not easy on these engines, needs to be just right) and rear main seal. Mine has not leaked in about six months.
Good Luck.
Old October 19th, 2011, 9:01 PM
  #58
bacon7's Avatar
Thanks kiethkman, Ill change the pan gasket and see how if it works.
Old October 20th, 2011, 9:29 AM
  #59
KeithKman's Avatar
I can't promise you anything, as every truck is different. All I can do is share my experience.
I hope it works out!
Old January 2nd, 2012, 11:35 AM
  #60
01z71's Avatar
Alright guys, I am back. Howver this is just an update. RC Performance found another leak that the dealer didn't find almost 2 years ago. He replaced a block off gasket. All Richard told me was that when Chevy doesn't use an engine oil cooler, it blocks it off. He replaced the gasket. I was there maybe an hour at the most. Very inexpensive fix. He asked me if I always noticed oil on the filter. I said "yes." He asked, "how long." I told him for 2 yrs. He told me I might have had that leak 2 yrs. Either way, I have put 200+ miles on the tahoe and no oil on the filter. I think this chapter in my life is about to end.
Now, on to replace worn out electric shocks in the front, airpressured shocks in the rear, and the oem air compressor in the rear.
If I develop another leak, I will let you guys now.
Happy New Year,
Quick Reply: 2001 Tahoe oil leak
