2001 Tahoe P0442 and P446 won't sart
Professional Mechanic
RE: 2001 Tahoe P0442 and P446 won't sart
po 442 is a evap system small leak dectected and po446 is evap purge solenoid malfunction. It is unlikly that these have anything to do with the no start. It could be possible that it has a mayjor vac leak in the evap system causing the engine to get to much air. look for a giant vac leak
The gas cap can cause the po442 if it is loose or bad.It is possible that it will cause the po446 if it is missiing but in any case the gas cap will not cause a no start.
camotruck55
Silverado & Fullsize Pick-ups
December 15th, 2011 1:53 AM
EddieClassic07
December 11th, 2011 1:53 PM
