Code p0410 on 01 tahoe
Old November 3rd, 2010, 8:42 PM
DEEZ_2010's Avatar
Default Code p0410 on 01 tahoe
Newly member and first post. I took my 01' tahoe to the dealership to get a diagnostic because the check engine light came on.The print out they gave read "P0410 - AIR INDUCTION SYSTEM FAILURE. I did some re-search online it mention's a vaccum hose leak, a hose is leaking air, or a faulty air pump. I hope someone can help me.
Symptoms are as followed:
1. The car turns off when doing a sharp turn or a U-turn.
2. The voltage meter goes to 9 when not stepping on the accelerator ( when stuck in traffic on the freeway)
3. Going thru railroad tracks or dumps not stepping on the accelerator it turns off.
I hope this helps in trouble shooting. Thank you
Old November 3rd, 2010, 9:13 PM
Welcome to the forum...
sounds like you might need to check the battery cables and ground cables
the code could be symptom and not a cause...
make sure all battery connections are tight at all points, the starter, the engine, alternator.
check for any corrosion...
Old November 3rd, 2010, 10:22 PM
DEEZ_2010's Avatar
Default Checked
My battery has proper voltage, auto zone checked the alternator and starter which was good. Any other suggestions?
Old August 29th, 2013, 12:10 AM
avarenal's Avatar
have a 2001 GMC Yukon 5.3l and have the p0410 code coming up. changed gas cap, purge solenoid, spark plugs, air pump, air pump relay, charchoal canister and still getting code. I did noticed that the air pump goes off while driving at times, which I know should not. I live in CA which is dry and checked the pump and no water or moisture what so ever. Any ideas?
DEEZ_2010
August 29th, 2013 12:11 AM
roboman
January 3rd, 2013 9:30 PM
1968ss
July 23rd, 2011 7:22 AM
jbi
June 16th, 2010 10:19 AM
maddawg
Cobalt
May 23rd, 2009 8:57 AM
Quick Reply: Code p0410 on 01 tahoe
