2003 6.0 Temp question
#12
Just an update, autozone and O'Reilly have 2 part numbers for ,these trucks.
The one with the extra tang on top did not fit my truck. This is the 1 piece version, it has the thermostat built into the housing.
The one with only 2 bolt holes has a separate thermostat and that's the one that fit. I guess in the long run this might be better because now I can buy a t-stat for 12 bucks instead of buying the housing everytime.
Note: the one I pulled out only had 2 holes in the housing and it had the thermostat built in, so for this time I did have to buy a housing but next time I can just get a thermostat. I probably should have waited and gone to the dealer but it Sunday and they are closed.
#15
50/50 or less of coolant. Coolant does not cool well, water does. Some guys run 20-40% coolant. Trust me I live in Phoenix I know extreme hot.
#17
That is not true. Look at the label, it indicates more concentration of coolant, the better levels of protection in colder, and hotter weather (freezing point, and boiling point is lowered, and increased)
#18
Water is a much better heat transfer fluid than ethylene glycol or propylene glycol.
Engine coolant's primary job is to transfer excess heat from the engine to the environment.
The engine cooling system is engineered to take advantage of water as the primary heat transfer fluid. Water is assigned a heat transfer value, specific heat, of 1.0.
Other fluids are compared to water. Higher vales transfer heat more poorly, while vales of less than 1.0 would transfer heat more efficiently. Ethylene glycol has a specific heat of 2.78, and propylene glycol has a specific heat of 2.73. At 50% water and 50% antifreeze, the specific heat of engine coolant is much closer to that of water.
This illustrates the necessity of mixing water and antifreeze to make engine coolant!
In very warm areas some operators use water with corrosion inhibitors. The use of water is successful because although the boiling point is lower than with glycol-based antifreezes, the heat transfer is better, and the operating temperature of the engine often decreases enough to avoid boil-over problems.
http://blendtech.biz/antifreeze-info...roperties.html
#19
That is ture, water can move heat much better than the glycol, but it cannot hold as much heat as it. When you are standing still, there is not as much cooling going on for a gasoline engine. Thus standing still which so much water, so of course you are going to starting exceeding the amount of heat the water can hold quite quickly.
#20
Just wanted to update this thread. I replaced the water pump, fan clutch and T-Stat with coolant drain and refill. Truck ran for 40 min in the driveway with both the front and rear AC on in 92* heat and barley moved from the 1/2 mark.
The dealer wanted just over 1k to do the work. I only asked because I was curious. I bought parts for just over 200 bucks and did it myself. It's actually pretty easy on these trucks and for 200 bucks I figured I may as well change it.
