2003 suburban LT gear selector - Chevrolet Forum - Chevy Enthusiasts Forums
seattle206's Avatar
July 29th, 2010, 3:08 PM   #1
hey guys,
so my dads 03 suburban about a year had the speedometer stop working, so we sent it in to a guy on ebay who said he cleaned and replaced everything.
anyway about 6 months ago the gear selector indicator on the dash just above the mileage kind of went out, sometimes it will come on perfectly but 95% time it is too dim to even see what gear you are in.
yes the dimmer is on full and you still cant see it, so ive taken the cluster out and played with the wiring and it seems that it only brightens up when you pull the plug about half way out. so im wondering is this probably and electrical problem or could it be the guy never replaced that bulb and it is starting to fade?
thanks guys
KC, MO area
July 29th, 2010, 3:21 PM   #2
Welcome to the forum.
Sounds more like a dirty/bad connector problem. Get some spray contact cleaner at Radio Shack or similar store.
seattle206's Avatar
July 29th, 2010, 10:33 PM   #3
tried that contact cleaner, didnt help. it seems to get better and worse depending on how you move the wires and the connector, but has no certain spot that makes it like new.
the odometer right below it works fine, so maybe its the wire and pin for the gear indicator?
LARIDERS's Avatar
Michigan
July 29th, 2010, 10:37 PM   #4
sounds like a loose wire or pin.
seattle206's Avatar
July 29th, 2010, 11:40 PM   #5
Any place to see a wiring diagram and see what pin it is?
LARIDERS's Avatar
Michigan
July 30th, 2010, 12:20 PM   #6
see if this helps. not sure if it is the right one.
seattle206's Avatar
July 30th, 2010, 12:32 PM   #7
thanks!!
now if im reading this right it will be the dark green with white wire correct?
seattle206's Avatar
July 30th, 2010, 1:23 PM   #8
ok well i tried jiggling all the wires in the plug and again nothing worked unless you move the plug a certain way then it appears but slowly dims again.
so im thinking i might just have to replace the cluster?
KC, MO area
July 30th, 2010, 7:04 PM   #9
Can you disassemble the cluster enuf to see what the connector is mounted on? If it's directly soldered to the printed circuit board, it may be a cracked solder joint which is an easy fix.
seattle206's Avatar
July 30th, 2010, 7:42 PM   #10
i can try that when he gets back home he is gone for the weekend.
whats the best way to take it apart? i think when i first took it out a year or so ago i was going to take it apart but it seemed like i was doing it wrong
Tags
Sponsors
  • Ask a Question
    Get answers from community experts
What's your question?
Send
