2005 Suburban Speedo not working properly
Hello. New to the forum but lurked some before I joined. Seems like a knowledgeable, helpful group. Just recently got a 2005 Suburban LT. Has a intermittant speedo problem. Sometimes works, sometimes not at all, and sometimes doesn't read correctly. Cruise works wether or not the speedo is working and the odometer and associated ( avg milage, trip, etc) seems to work as well. Xfer case was replaced before I got it but not sure if that had anything to do with it, and I don't have a diagram (yet) to check wire connections. All other gauges seem to work fine, just the speedo acting up.
Any comments/suggestions as to where to start troubleshooting are greatly appreciated.
thanks,
Tom
thanks,
Tom
FYI - I never did do anything about mine. From what I read it seemed to point to the stepper motor(?) going bad. Didn't want to sink money into the speedo and then have the others possibly go as well - thought it would be better to do all at once or replace the cluster if I could find a used one cheap. In the meantime I have a garmin GPS that tells my speed. Since all my other gauges work and that tells me how fast I am going it has dropped down the priority list for me. Mine has other more important issues I need to take care of first. Good luck.
My '05 had 90,000 when this happened. After some research and diagnostics, we determined that my trouble was in the instrument cluster. It takes all of about 5 minutes to remove it with only a nut driver. I shipped it off to Tacoma Speedometer and had it back in less than a week. They have a one day turn around on their end. They replace the motors with OEM parts, replace LED's, and clean everything out.
It was about $200.00, but it was fast. And they used real parts. Not the crap you'll find in a $50.00 instrument cluster. Been flawless since I put it back in. Reinstall was also a 5 minute job.
Stepper motor replacement
I had the same problem with my 2003 Silverado. I followed the directions for speedometer repair on this site and all is good again. Cost about $25-30 dollars.
The guage cluster on these vehicles does not have a recall but it is a known problem with GM. I have a packet of papers the dealer gave me 2 years ago when I bought an '03 burb 2500. Had my cluster replaced for free. The speedo hung at 55 mph the day I drove it home! Talk to a dealer. Covers '03-'05 models
Doc. ID: 2253005
#07187c: Special Coverage Adjustment-Instrument Panel Cluster Guage Needle Function-
Doc. ID: 2253005
baldana
Silverado & Fullsize Pick-ups
19
January 25th, 2018 2:16 PM
jbravo8212
November 25th, 2007 8:35 PM
occa9
November 1st, 2007 12:39 AM
