Last edit by: IB Advertising
Browse all: Lighting Guides
- Chevrolet Silverado 2014-Present: Headlight Bulb Review
Review and comparison to top products
2007 Tahoe HEADLIGHT BULB REPLACEMENT?
#11
2007 Tahoe Headlight Bulb Replacement
Replacing the bulb on my 2007 Tahoe looked like an onerous task. Removing the wheelwell cover, bumper mount, grill holder and then risk scratching the finish with the tabs on the headlight. I figured out an easier way to replace the headlight bulb on the passenger side.
1. Remove Air Box
a. Remove Air Filter
b. Pull box out. Not screwed into anything, uses inserts.
2. Behind headlight is a rubber membrane cover.
a. Pullout push pin (use channel locks or offset pliers to assist)
3. Loosen top two bolts holding Light fixture
4. With the fixture loosened push the headlamp forward to get more clearance (1/4-1/2 inch should do it). You should be able to twist the bulb counterclockwise, remove and replace bulb and insert into light fixture twisting clockwise.
5. Push headlight fixture into original position and tighten. You may want to mark its original position.
6. Put on light to make sure it works
7. Tap in push pin on membrane
8. Place air box bottom in original position and push in until it connects (may have to jockey a bit to find position)
9. Replace Air Filter, 4 screws and hose clamp.
I'm awaiting for the driver's side bulb to go but on observation it seems I could pull the spare battery plate and wiper wash reservior. There's a membrane cover behind that light as well.
1. Remove Air Box
#12
For those of you that installed new HID bulbs and ballasts on the driver side without moving the headlight out for access must have small hands! Did you guys install the ballast somewhere else?
#13
FYI for those w/ HIDs: Might want to turn the "Approach lite" feature off so you don't have the headlites on and then they turn off when you start the engine and then back on. I've heard that can cause early failure.
#14
What is replacement bulb for DRL?
Hey guys, thanks for all the great information on how to change out the front headlights. You have saved a lot of people a lot of hours. Before I begin taking apart the passenger side of my 2007 Suburban, I wondered if anyone knows what bulb I need for the DRLs. Thanks!!
#15
the DRL is
Daytime running light
3157LL
here is the rest of the lamps..
2007 CHEVROLET Tahoe
Low beam headlamp
H11
H11XV XtraVision Halogen - The Brighter Light
High beam headlamp
9005
9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9005XV XtraVision Halogen - The Brighter Light
9005CB Cool Blue Halogen - The Whiter Light
Fog light
H16
Parking light
4157NALL
4157AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
Front turn signal
4157NALL
Rear turn signal
3057LL
Tail light
3057LL
Stop light
3057LL
High mount stop light
LED
Fog/Driving light
5202
License plate
2825LL
Back up light
7441
Front sidemarker
2825LL
Map light
212-2
Dome light
212-2
Trunk/Cargo area
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
3157LL
3157LL
Low beam headlamp
H11
High beam headlamp
9005
Fog light
H16
Parking light
4157NALL
Front turn signal
4157NALL
Rear turn signal
3057LL
Tail light
3057LL
Stop light
3057LL
LED
Fog/Driving light
5202
License plate
2825LL
Back up light
7441
Front sidemarker
2825LL
Map light
212-2
Dome light
212-2
Trunk/Cargo area
921
3157LL
#16
the DRL is
3157LL
Low beam headlamp
H11
High beam headlamp
9005
Fog light
H16
Parking light
4157NALL
Front turn signal
4157NALL
Rear turn signal
3057LL
Tail light
3057LL
Stop light
3057LL
LED
Fog/Driving light
5202
License plate
2825LL
Back up light
7441
Front sidemarker
2825LL
Map light
212-2
Dome light
212-2
Trunk/Cargo area
921
3157LL
3157LL
Low beam headlamp
H11
High beam headlamp
9005
Fog light
H16
Parking light
4157NALL
Front turn signal
4157NALL
Rear turn signal
3057LL
Tail light
3057LL
Stop light
3057LL
LED
Fog/Driving light
5202
License plate
2825LL
Back up light
7441
Front sidemarker
2825LL
Map light
212-2
Dome light
212-2
Trunk/Cargo area
921
3157LL
#18
in2pro, this is sooooo very helpful. Always seems to be conflicting numbers on bulbs in message boards. You have listed everything here and made the shopping trip much easier. Thanks for taking the time out to list.
This is the second time in three months - such a pain in the butt to change bulbs on this model.
#20
video
thank you for the video! Luckily all of my 6 year old bulbs in the headlights still work fine. I don't want to do this job...
The headlights in that video are BEAT. How did this person even see at night?! I didn't think the 07-14 Tahoe headlights would fade that bad... I've seen it bad on older cars. We replaced the ones on the Mazda for yellowing. NIGHT AND DAY difference. But that's 10 years old... I guess they all yellow?
