Notices
New Wheels and Tires for my 2001 Suburban???
Old September 23rd, 2013, 12:26 PM
boshno's Avatar
Default New Wheels and Tires for my 2001 Suburban???
I just bought a beauty 2001 suburban and would like to buy nice new shoes for it. it's stock car and I was thinking to put 20" rims with 285/55R20 Terra Grappler tires and would like to get anyone's opinion if these wheels and tires would be ok without installing the lift kit. Thanks in advance for your opinion!!!
Old September 23rd, 2013, 1:59 PM
SWHouston's Avatar
Been done several times by properly using a 9"x 20" Rim. Your overall diameter is going to be 32.5" which you'll have to just deal with on the Speedometer and other issues related to a larger tire.
Just make sure that the Rim Manufacturer guarantees that the Rim you select/they recommend for your specific vehicle, has sufficient offset where the Tire won't scrub/rub.
PS:
Burbs are Trucks, not Cars
Old September 23rd, 2013, 4:00 PM
Welcome to the forum.
Also make sure that your wheel will clear the calipers.
Old September 25th, 2013, 12:00 PM
country_09's Avatar
Should be fine, but like said gettin the proper rim is key. Width a offset play a big role in what tire size will fit without trimming
Old September 25th, 2013, 7:21 PM
If you get some minor rub on the wheel house plastic liners, you can reshape using a heat gun instead of just cutting them.
JHarris8732
Silverado & Fullsize Pick-ups
November 10th, 2011 11:25 AM
dphd
April 21st, 2011 1:17 AM
scootr68
July 23rd, 2010 6:06 PM
BlueTahoe2001
May 17th, 2009 4:21 PM
new_york_system
March 27th, 2007 1:30 PM
Quick Reply: New Wheels and Tires for my 2001 Suburban???
