2008 Suburban - Fluid Leak
Old November 26th, 2014, 5:58 PM
joeincharlotte's Avatar
Default 2008 Suburban - Fluid Leak
Hey guys. I recently noticed a drip on my driveway that looked like oil. I got underneath and found the oil filter was a bit loose. I thought it was that. When I took it to the dealer to have them service it, I asked them to check if I had an oil leak. I was told that I didn't. Well fast forward a couple of months and it's back. It started dripping again, black drips. This time I crawl underneath, the filter is nice and tight, but the transmission pan has a coating of fluid on the underside, the stabilizer bar has some, so does the whole underside of the tranny housing.
Anyway, long story short, I can't seem to figure out where this is coming from. It doesn't look like transmission fluid, but I'm going to replace the pan seal this weekend anyway. Some of the bolts there look like they have a leak. Anyone have any thoughts on this? Couple of pics to show reference.
See the drip on the bolt next to the filter:
Transmission pan:
Old November 26th, 2014, 6:43 PM
It looks like crankcase oil from what I can tell in the picture. You need to use some brake cleaner and clean it all off and then check it a few days later.
Old November 28th, 2014, 12:09 PM
zold1's Avatar
Default Oil Leak
Oil generally won't travel forward, unless it is running down something, then in large quantity. I would look at the farthest point forward that you see the oil. It looks as if the rear main is leaking, just guessing, by the thin film of oil. Take the flywheel cover off and see if the oil originates up around the rear of the crank.
Old November 29th, 2014, 4:24 PM
All things I was hoping to avoid....thanks for the help. Will spray it down tomorrow and see what happens. If it's the rear main, I'm probably going to trade it in. I'm tired of fixing things on a 6 year old truck.
Old December 1st, 2014, 7:47 AM
Do you have an external oil cooler, if so it may be the lines that connect to the filter mount housing...
I agree with the above suggestions, get it cleaned up and watch it daily for a week or so... and keep in mind that the oil is likely being blown back on everything adding to the mystery leak location...
Doug Suburban
March 23rd, 2013 9:05 AM
John O
Silverado & Fullsize Pick-ups
March 31st, 2010 2:29 AM
DeHartShadow
March 28th, 2010 10:10 PM
junklady
October 28th, 2009 6:01 PM
Quick Reply: 2008 Suburban - Fluid Leak
