2008 Tahoe Power seat electrical problem
Old March 2nd, 2014, 1:45 PM
engine73driver's Avatar
Default 2008 Tahoe Power seat electrical problem
Hi all... My 2008 Tahoe's power seat was stuck in the rear position. Mechanic told wife $700 to fix. Ha, Im no sucker. I removed the seat to expose the seat motors. Tested the motor and found power only to the wire controlling rear movement.. No power to front movement. I routed a wire directly from battery to the wire controlling frontal movement and returned the seat to a good position temporarily. My question is that since I get the seat to work by bypassing everything, what part do I need to fix it for good? A relay, a control module of some sort? I dont know. Thanks in advance.
Old March 2nd, 2014, 2:03 PM
Welcome to the forum, well now that you know the motor works, I would track down those very items you mentioned... Check the fuses, check the relays, check the switch to the seat, check the wire-harness....
I'd start by working from the fuse forward...
Old March 2nd, 2014, 2:16 PM
Thanks. I'll get on it. I appreciate your help.
Davidc21a
May 8th, 2018 7:29 PM
Dcebel01
June 3rd, 2015 1:30 PM
sardarkhan
May 16th, 2012 3:02 PM
fastback4
December 21st, 2008 7:04 PM
n8tgc
March 9th, 2008 3:44 PM
Quick Reply: 2008 Tahoe Power seat electrical problem
