24's vs. 26's
#22
RE: 24's vs. 26's
you are right on with your points.. i noticed the lack of torque right off the bat with my 305/35-24s.. i also said goodbye to AFM/V4 mode...
I bought an 07 Escalade EXT in addition to my Tahoe..and it pull nice with the larger rims. I really wish they offered a 6.2 in the Tahoe. btw, I'm sure the 4.10 gears would have helped your 26 inch cause.
ORIGINAL: w00t
So after only 1 day here are my observations about the converstion from stock wheels/tires to 26's.. [ol][*]Definitely notice sloooooow starts off the line, guess it takes much more torque to get those beasts rolling. Wondering if I should have gone Denali instead of the LT3 to get the bigger motor + 6 speed instead of Flexfuel - basically they are the same price.[*]At highway speeds it's much less likely to kick into V4 mode?!!? Even a moderate downhill w/cruise control on.[*]Ride quality is as expected, not bad but noticeably choppier then stock. Definitely acceptable in my opinion.[*]Clearance. No major problems thus far, heard minimal rubbing when entering steep driveways at low speed or when turning hard at low speeds. I suspect a little fender well trimming may be required, more updates to come. [/ol]26's without lowering is by far the way to go. Still have clearance for when I need to go into 4WD, and the fender wells fill out really nicely. I couldn't imagine the ride quality with big wheels AND lowering springs... Save the $$ on the lowering kit (and alignment) and get 26's
#24
RE: 24's vs. 26's
Here are my 26's on my ltz. They don't rub at all but I put a leveling kit on the front.
[IMG]local://upfiles/8424/27E6442B9B4844079A074B84632F9A82.jpg[/IMG]
[IMG]local://upfiles/8424/4C392714063C47408C0DB3A96AEC9442.jpg[/IMG]
[IMG]local://upfiles/8424/AD5AC73605164B8781ED250D094B1786.jpg[/IMG]
