3 sensors for automatic a/c control... what are they and where?
#11
RE: 3 sensors for automatic a/c control... what are they and where?
shawnvw nice diagram im assuming the automatic/digital system is going to be different. where are the hvac modules located? under the hood? seems like I would have to change hvac modules and wiring harnesses for it to work, hopefully not the whole blower system and what not.
#12
AUTOMATIC SYSTEM
HVAC Control Module C1
Connector Part Information[*]OEM: 15491305[*]Service: 15126709[*]Description: 20-Way F USCAR 0.64 Series (BN)
Terminal Part Information[*]Terminal/Tray: SAITS-A03T-M064/14[*]Core/Insulation Crimp: P/P[*]Release Tool/Test Probe: J-38125-215/J-35616-64B (L-BU)[*]
Pin
Wire Color
Circuit No.
Function
WH/BK
5515
Inside Air Temperature Sensor Assembly Control
2-3
Not Used
D-GN
734
Inside Air Temperature Sensor Signal
GY
1548
Passenger Sunload Sensor Signal
BN
404
Upper Air Temperature Sensor Signal (C69)
L-GN
405
Lower Air Temperature Sensor Signal (C69)
8-13
Not Used
14
D-GN
5518
Auxiliary Inside Air Temperature Sensor Signal (C69)
15
L-BU/BK
590
Driver Sunload Sensor Signal
16
TN
516
Upper Left Air Temperature Sensor Signal
17
TN
517
Upper Right Air Temperature Sensor Signal
18
PK
2145
Air Temperature Switch Signal - Right (C69)
19
GY
2599
Auxiliary Mode Door Control (C69)
20
Not Used
HVAC Control Module C2
Connector Part Information [*]OEM: 15491285[*]Service: 15136073[*]Description: 16-Way F Kaizen 0.64 (BK)
Terminal Part Information [*]Terminal/Tray: SAITS-A03T-M064/14[*]Core/Insulation Crimp: P/P[*]Release Tool/Test Probe: J-38125-215/J-35616-64B (L-BU)
[ul][/ul]HVAC Control Module C2
Pin
Wire Color
Circuit No.
Function
RD/WH
3340
Battery Positive Voltage
2-3
Not Used
L-GN/BK
735
Ambient Air Temperature Sensor Signal
D-GN
5060
Low Speed GMLAN Serial Data
D-BU
204
A/C Low Pressure Sensor Signal
Not Used
BK/WH
1851
Ground
OG
300
Ignition 3 Voltage
10
WH
193
Rear Defog Relay Control
11-14
Not Used
15
BK
1050
Ground
16
D-GN
6101
Low Reference
HVAC Control Module C3
Connector Part Information [*]OEM: 15491304[*]Service: 15126710[*]Description: 20-Way F USCAR 0.64 Series (GY)
[ul][/ul]Terminal Part Information[*]Terminal/Tray: SAITS-A03T-M064/14[*]Core/Insulation Crimp: P/P[*]Release Tool/Test Probe: J-38125-215/J-35616-64B (L-BU)
[ul][/ul]HVAC Control Module C3
Pin
Wire Color
Circuit No.
Function
TN
518
Lower Left Air Temperature Sensor Signal
YE/BK
713
Defrost/Heater Mode Valve Position Sensor Signal
PU
1838
Recirculation Door Position Signal
GY/BK
754
Blower Motor Speed Control
5-9
Not Used
10
GY
598
5-Volt Reference
11
TN
520
Lower Right Air Temperature Sensor Signal
12
L-BU
733
Air Temperature Door Position Signal
13
D-BU
1646
Auxiliary Air Temperature Door Position Signal (C69)
14
Not Used
15
TN
2273
Mode Door Control
16
D-BU
1199
Air Temperature Door Control
17
D-GN
1614
Recirculation Door Control
18
WH/BK
1236
Auxiliary Air Temperature Door Control (C69)
19
Not Used
20
YE
1791
Low Reference
HVAC Control Module C4 (C69)
Connector Part Information[*]OEM: 15483874[*]Service: 21997401[*]Description: 16-Way F Kaizen 0.64 Series (GN)
[ul][/ul]HVAC Control Module C4 (C69)
Pin
Wire Color
Circuit No.
Function
Not Used
GY
596
5-Volt Reference
OG
2215
GY
2614
Not Used
GY/BK
1798
Low Reference
BN
5516
8-9
Not Used
10
D-GN
2211
Auxiliary Blower Motor Speed Control
11-16
Not Used
Pin
Wire Color
Circuit No.
Function
WH/BK
5515
2-3
Not Used
D-GN
734
GY
1548
BN
404
L-GN
405
8-13
Not Used
14
D-GN
5518
15
L-BU/BK
590
16
TN
516
17
TN
517
18
PK
2145
19
GY
2599
20
Not Used
Pin
Wire Color
Circuit No.
Function
RD/WH
3340
2-3
Not Used
L-GN/BK
735
D-GN
5060
D-BU
204
Not Used
BK/WH
1851
Ground
OG
300
Ignition 3 Voltage
10
WH
193
11-14
Not Used
15
BK
1050
Ground
16
D-GN
6101
Low Reference
Pin
Wire Color
Circuit No.
Function
TN
518
YE/BK
713
PU
1838
GY/BK
754
5-9
Not Used
10
GY
598
5-Volt Reference
11
TN
520
12
L-BU
733
13
D-BU
1646
14
Not Used
15
TN
2273
Mode Door Control
16
D-BU
1199
17
D-GN
1614
18
WH/BK
1236
19
Not Used
20
YE
1791
Low Reference
Pin
Wire Color
Circuit No.
Function
Not Used
GY
596
5-Volt Reference
OG
2215
GY
2614
Not Used
GY/BK
1798
Low Reference
BN
5516
8-9
Not Used
10
D-GN
2211
11-16
Not Used
#13
I've also just noticed after going through a few diagrams,the recirculation actuator, in the automatic system,has an extra wire to tell the hvac control module in what position it is in
And the HVAC control module is the controls in the dash. It is the brains of the unit
#16
shawnvw, i hate to keep bothering but after seeing all these diagrams I started to think even more thoroughly.... since I changed my whole entire dash from an lt1 to a ltz, that means that not only did the hvac module (digital a/c control switch) come with the new dash, but also the wiring for it, including to the bcm. I talked to my friend whom is a tech at chevy and he told me that he had programmed the bcm to automatic a/c from manual a/c (which is probably why my a/c is working right now). So with the dash also came the duct work, and I'm assuming that the air temp sensors are already included. All i'm really missing is the incar sensor above the drivers head and the sunload sensor. Does the wiring to the blower and such (on the right side above passenger foot well) change at all from manual to automatic? Obviously they do at the control switch, but I recall that I didnt need to disconnect any harness from that whole unit behind the pasenger glove box, I hope that made sense lol.
#17
between the auto and manual controls, the wiring is exactly the same as far as the blower motor is concerned. There is 1 wires that comes from the controls to a blower motor module, whihc is really a solid state resistor. Which in turn powers the blower motor and changes speed based on the signal from the wire from the switch. That wire varies from 0-5v depending on fan speed chosen.
I would agree with you when you say "So with the dash also came the duct work, and I'm assuming that the air temp sensors are already included. " So by getting the temp sensor above the drivers head.....which I must say is more than just a sensor, it has a small fan in there that draws air in over the senser......and by also getting the sunload sensor....I think you'd be pretty close to getting this unit working.
And no worries about bothering me...we're here to help guys like you who want to do things themselve out. I do it cause I like to keep on top of things I don't normally dig into.
#18
yeah I really appreciate it, luckily the tech at the dealer who worked on my car was cool and I became friends with him. Him and others laughed at what I had been doing with the conversion. As far as that extra wire to the blower motor, apparently I must have it already connected because the fan speeds work perfectly. I already ordered the sunload and incar sensor BUT the incar sensor is going to take a little more time, since my roof/headiner wiring harness is different from what I need. Its fine because I will be installing a factory sunroof so I needed to get the new headliner and harness anyway.
Bxutista (August 13th, 2019)
#20
11 years later...
do you happen to have a video of he process?? Is it worth it
