91 Suburban 2500 wont move
Old June 18th, 2013, 5:51 PM
  #11
djbeatz87's Avatar
ok these are all from under "Big Red" as we have come to call it...taken from passenger side looking up.
Attached Thumbnails 91 Suburban 2500 wont move-0618131624.jpg   91 Suburban 2500 wont move-0618131624a.jpg   91 Suburban 2500 wont move-0618131624c.jpg   91 Suburban 2500 wont move-0618131625.jpg   91 Suburban 2500 wont move-0618131626.jpg
Old June 18th, 2013, 6:37 PM
  #12
djbeatz87's Avatar
any ideas?Anyone? Please? Toyotas and Nissans I can do all day but I really want to learn from people who have done this before.
Old June 18th, 2013, 7:40 PM
  #13
Joe In NY's Avatar
what about the end of the hose??
Old June 18th, 2013, 8:13 PM
  #14
djbeatz87's Avatar
There is quite a length of hose...maybe 3 ft or so and then this on the end. it looks like it melted against the exhaust
Old June 18th, 2013, 11:44 PM
  #15
cleveland63b's Avatar
no fluid on the dipstick? you checked it in park idling right? In most cases if its driven low on fluid until it doesnt move the transmission is burned up...did the dipstick smell hot/burnt at all?
My next step would be to drop the oil pan and check for metal, take the filter a part and check for metal in it also.
Old June 20th, 2013, 3:08 AM
  #16
djbeatz87's Avatar
No burnt smell from on the dipstick or fluid. It was driving smooth all day. I backed it into a parking space and parked it. When I came out two hours later, it went forward, but being a burb, doesnt maneuver the best. I put it in reverse and it still wanted to go forward. So I put it in park and turned it off. When I started it back up, nothing. No response in any position on the column. If it burned out, wouldnt I have seen smoke or noticed slippage or some kind of sign? It was just serviced in January and has driven great.
Old June 20th, 2013, 9:07 AM
  #17
Joe In NY's Avatar
Transmission are not engines. They don't smoke because they are full of fluid. In transmission your clutch's can go bad, valve solenoids can go bad, passages get blocked up, valve parts break, springs for the valves break... If there is debris it could have worn away parts.
Transmissions "burn out" very differently than engines. Transmissions are you could say, fragile, picky, etc. They have to be clean and have good fluid for proper operation. Other wise they are slowy and sometimes rapidly destroying them selves.
Old June 20th, 2013, 8:19 PM
  #18
djbeatz87's Avatar
Got ya... well Ill drain the fluid and drop the pan next and see what we have going on. Ill post pics as I go.
dberladyn
Express & G-Series Vans
30
June 24th, 2015 10:28 PM
Doug Mercer
Silverado & Fullsize Pick-ups
March 24th, 2011 11:30 AM
backcountry
October 19th, 2009 10:13 PM
suggashak
April 22nd, 2006 4:48 PM
Quick Reply: 91 Suburban 2500 wont move
