1995 Burb brake control install help needed
Hi,
I just bought a prodigy brake control and I'm looking for guidance as to which wires I need to splice into. I guess I am hard wiring it...stupid me, I thought I'd just be plugging it in.[>:]
RE: 1995 Burb brake control install help needed
well there's going to be no way around using a test light and probing the wires to find the cold side of the brake light switch i think the switch is above the brake pedal using a white wire .push the pedal when you probe it to find the hot and cold side i don't know if the wire connector's are to were you can just touch metal end with out probing the insulation .good luck .
tippy28
Silverado & Fullsize Pick-ups
July 1st, 2009 6:03 PM
