Notices
97 suburban torsion bars?
Old December 2nd, 2008, 7:59 PM
baddog15's Avatar
Default 97 suburban torsion bars?
Hey everyone I have a 97 chevy suburban 5.7 l LT 4X4 K1500 suburban . Someone was telling me that i could gain about 1-2 inches of a lift if i tightened the torsion bars? i think i know where they are but what would i need to do to do this, take it to a shop or can i do it myself? what are the pros and cons of doing this? is it a good idea? thanks for the help!
Old December 3rd, 2008, 10:28 AM
old dog's Avatar
Default RE: 97 suburban torsion bars?
you are only going to lift the front with the torsion bars ,why do you want to do this ? to level it out ? if you do it you will have to realign the front end or the tire will wear adversely . need a little more info please .
Old December 3rd, 2008, 2:07 PM
bad2006z71's Avatar
go on ebay and type in chevy leveling kit. it allows you to lift the front in roughly 2" without cranking the bars. cranking the bars alone will give a shi*tty ride, the keys wont be as bad. lifting 2" wont wear out the front end that badly.
Old December 7th, 2008, 8:21 PM
Red Dog's Avatar
I cranked up the torsion bars on my 1999 Suburban after I added the grille guard. A couple of turns on both sides, and I recovered the drop from the additional weight out front. No adverse affects have been noted so far. I did not want a lift; just wanted my OE height back.
Hope that helps,
-JR
Old December 7th, 2008, 8:35 PM
old dog's Avatar
better have the alignment checked !
Old December 8th, 2008, 2:52 PM
Red Dog's Avatar
I purchased a new set of Goodyear Silent Armor tires in LT285-75R-16 load range E right after the grille guard and torsion bar adjustment. Expecting a problem, I had an alignment included. If the alignment was off, they made it right. The tires have worn well, and there was no adverse affect to the ride quality. I was very satisfied.
Thank you,
-JR
davbell22602
Suspension & Tire
January 9th, 2010 5:46 PM
BlkSilv01
Silverado & Fullsize Pick-ups
July 6th, 2009 8:21 AM
robertmack83
May 29th, 2009 4:53 AM
jmckeage
February 19th, 2009 10:39 AM
ussva
June 3rd, 2008 12:07 AM
Quick Reply: 97 suburban torsion bars?
