AC not working after radio install
My son changed radio in my 96 suburban & now a/c won't work. Only Hot air Blowing & only window defroster works. Hope Some one can help me.
Welcome to the forum...
I'd be my guess that the blend door actuator motor got knocked loose or the control wiring is not connected... may also want to check all fuses as something could have been shorted....
If any of the wiring was cut to access power it could be a wire pulled back out of a connector...
Need to check the wiring under the dash and retrace all the areas touched during the install.... something is loose,cut, shorted or blown or binding....
Is the compressor coming on when the AC is turned on?
m_mek
Silverado & Fullsize Pick-ups
19
May 22nd, 2023 10:57 AM
salchipapa619
September 15th, 2009 6:10 PM
adamant
February 15th, 2009 8:49 AM
Roadblock
September 22nd, 2008 9:57 PM
