air level help
air level help
jump relay out for the pump to come on and nothing checked wiring seem no power coming from the relay even though jumped out anybody got a solution blue wire from relay to pump should have 12vdc does have at the contact but not at plug off the pump
air level trouble
07 suburban 150,000 miles and there seems to be no power coming from the relay to the pump jumped out 30-87 on relay but no power at the pump have 12vdc at the relay i then presum the wire maybe broke some wherr will try and run new wire if that seem correct
