another audio setup question
I will be replacing the speakers inside the hoe with aftermarket ones and also installing sub in the rear.
I am guessing the door speakers are 6.5 both front and rear.
the tweeters are located on the door pillar? and what size?
what kind of adapters will i need ( pac ) and what model number to run two amps( one four chanel for thefront and rear and one d amp for the subs) from the stock head unit while retaining the features.
i will not be using the stock amp.
I am trying to buy all the required parts for the install so i can just pay for the labor
( they alway try to rape you with the pricing on the eqiptment )
where are all the bose compomets located
RE: another audio setup question
For all those parts, we have them at SMM Enterprises, contact us at www.gosmm.com
You will need a PAC unit of some sort to keep your steering wheel controls, and if you are taking out the Bose amp I believe you need a PAC OS-3. If you leave the Bose amp in you will need the PAC OS-3 Bose.
ORIGINAL: scott_mckinney
Contact SMM Enterprises and buy it all from US, WE have the experience... www.gosmm.com
This thread will answer your speaker size questions:
https://chevroletforum.com/m_25667/mpage_2/key_/tm.htm
You can search this forum easily for other audio info. Believe me, there is a treasure trove of info here. Just have to dig it out.
No it won't, I made all that stuff up.
And uh engine,
just so you know, a sense of humor isn't going to be tolerated around here, please keep all posts as dry and to the point as absolutely possible and overcome any urge you may have to interject anything funny; even implied humor is out of the question.
That is all.
And uh engine,
That is all.
Chevrolet Forum News
January 14th, 2013 7:38 PM
crewxp
Silverado & Fullsize Pick-ups
12
October 25th, 2010 2:36 AM
