Motor Mounts?
Old September 8th, 2022, 6:51 PM
94burb's Avatar
Default Motor Mounts?
So I have an 07 LTZ Suburban with just over 200k mile and a fairly new suspension front and rear (shocks, upper and lower ball joints..) but I have recently noticed an odd clicking squeak when accelerating from a dead stop and has now turned more into a thump like sound. It sounds as if its coming from the driver side front end. I just inspected the front end system and found nothing and my last test was to hold the break down and try to accelerate which resulted with the biggest thump with power applied and then another thump when letting of the gas. I cant let my wife do this for me while i look under the hood cause... well you know..."ooopsie, sorry about that" as she rolls over me, accidental of course. Anyways... does that sound like motor mounts??
Any thoughts would be greatly appreciated
Old September 9th, 2022, 3:54 AM
oilcanhenry's Avatar
All your wife has to do is quickly hit the throtlle in park when you tell her to do so. Yeah on a Burb that old it MIGHT be motor mounts. Or you cn do it alone by using the throttle under the hood. It needs to be found and repaired thats a given.
Old September 9th, 2022, 8:25 AM
repairman54's Avatar
Yep motor or trans mounts. With hood open you should be able to see the motor jump doing it yourself in a clear area.
Old September 9th, 2022, 3:19 PM
Kenrbass's Avatar
You should be able to leave the hood open and partly stand in the burb while brake/accel test is done. I have been able to verify bad m mounts this way without help.
Old September 11th, 2022, 11:31 AM
94burb's Avatar
It is the driver side motor mount which I hear is a pain in the *** to replace with 4wd models
squeakytahoe
May 11th, 2017 4:36 PM
skram
February 1st, 2015 2:05 PM
alan07
Silverado & Fullsize Pick-ups
January 5th, 2014 6:36 PM
Lrayvick
August 17th, 2011 9:20 AM
slydog39
April 2nd, 2010 10:34 PM
Quick Reply: Motor Mounts?
