Old July 22nd, 2015, 12:38 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
A/C not blowing in front, only when moving. Rear, ok.
Old September 22nd, 2009, 6:38 PM
amerino28's Avatar
Question A/C not blowing in front, only when moving. Rear, ok.
I have a 2005 Chevy Tahoe. 58k miles. A/C worked perfectly until recently. Ok, So here is the problem. It started in late July. I have yet to take it in. I would like to see if this is something that I can repair myself. When the problem started, the front a/c would kick on only when it wanted to. Then about a week after this, the front a/c went out entirely. It only blows cool air when the truck is moving and if its NOT n recycle. The controls do not work either. The a/c and controls for the back passengeres work just fine. I do not know where to begin! lol Please help me!
Old September 22nd, 2009, 10:25 PM
Hardin Thicke's Avatar
Sounds like the main blower motor is shot. I believe the rear HVAC is on a separate blower. Does the defroster work? You're getting air while moving because it's being forced in when the control in on fresh air.
Old September 23rd, 2009, 3:16 AM
amerino28's Avatar
Thanks for your reply! I have to double check, but I THINK the defroster does work.. Ill have to re-post tomorrow a.m. to confirm this. Yes, that makes sense that I only get air while moving. Its cool air. like having a/c, just not blowing hard and no control. Do you this this may be a vacuum hose leak? Thanks!
Old September 23rd, 2009, 9:26 PM
If your defroster works, then it won't be a dead blower. I had to replaced mine once already and the motor is not cheap!
Old September 24th, 2009, 3:19 AM
amerino28's Avatar
I checked it, and it actually DOESN'T work. So you're probably right. I think I may take it in next week. It's under extended warranty. I will let the mechanics know to check the main blow motor.
Old September 25th, 2009, 6:44 PM
Did it not work on any blower speeds? It may be the speed select resistor.
Old September 26th, 2009, 2:23 AM
amerino28's Avatar
None of the speeds worked. The screen displays its on max A/C. It doesnt respond to anything.
Old August 6th, 2010, 4:35 PM
Nehyatt's Avatar
What was the problem. I
Having the same problem
Old August 11th, 2010, 5:57 PM
Nehyatt's Avatar
Default Ac
I'm having the same problem with my truck. I don't have warranty. Can anyone tell me what's the problem
Old August 11th, 2010, 8:52 PM
Welcome to the forum.
What year and model?
Quick Reply: A/C not blowing in front, only when moving. Rear, ok.
