Notices
2003 tahoe dash AC 4wd lights not working
Old January 12th, 2012, 2:13 PM
mwhitnell's Avatar
Default 2003 tahoe dash AC 4wd lights not working
My dash lights, AC led lights, 4wd leds, steering wheel lights do not work. The DIC info led works to dim when I use the thumbwheel reostadt. Everything worked until I had the transmission replaced. The mechanic said the bcm and ignition switch needed replacing. He programmed the BCM again. My thoughts are the BCM module is not programmed proper, any way that could cause the problem? I think the wire that goes to all the leds and incadescent indicator lights is brown. I was thinking about hot wiring the brown but not sure to where. All the dash instruments work. The 4wd and ac work, just no indicator lights.
buckmontana
October 15th, 2022 6:21 PM
dewijw01
August 22nd, 2014 9:26 PM
97 Tahoe "The Rig"
August 12th, 2014 9:45 PM
skdevore
August 26th, 2009 10:18 PM
bairdmj
June 7th, 2007 2:13 PM
Quick Reply: 2003 tahoe dash AC 4wd lights not working
