Clicking noise from the front left when turning right
I have been chasing this issue for 18 months. When I turn right I get a clicking noise from the front left wheel/hub area. I have changed the half shaft and then the hub, nothing same noise. I have 100k on the vehicle at 2004 4WD 2500 Suburban with a 6.0L.
Hub bearings or your brake pads may be loose. Lift it up and shake in a horizontal fashion to see if there is any end play. But likely hub bearings second would be brake pads jiggling.
When I changed the hub the bearings were part of the replacement unit. I did try the end play, none. I will check the pads. The noise increases with intensity and frequency a the more I turn the wheel. if zero is straight and 40 degrees is full right the noise starts at about 15 degrees.
Have you tried rotating the tires to make sure its not a nail or screw that is making hard contact with the pavement when turning?
Just a thought...
Just a thought...
when I replaced the half shaft the CV joints are included. I have pulled the tires and inspected them. I have been considering a suspension issue that maybe on the rack can find. Thanks for the replies, I think it is time to let a shop look at it.
tyer50
Silverado & Fullsize Pick-ups
December 22nd, 2021 4:06 PM
KennyK1500
September 26th, 2012 8:32 PM
JasonT
October 6th, 2009 10:56 AM
litcatp
June 4th, 2009 1:44 PM
