where is the heated mirror fuse on an '03
I cannot find the fuse for the heated mirrors on a 2003 'burb. I've read in an Haynes manual it may be marked htd/mirr but there's nothing in the 3 fuse locations marked.
If anyone's got the location I would be very grateful,
Julian
Julian
RE: where is the heated mirror fuse on an '03
Julian,
What you will be looking for is a 30A fuse in the Underhood Fuse Block marked "RR DEFOG", this fuse is located in the center towards the right side of the fuse block.
There is also a "DEFOG" relay in the Center Instrument Panel Fuse Block, the center instrument panel fuse block is located underneath the instrument panel, to the left of the steering column, the "DEFOG" relay is the small square relay located dead center in the block.
Dave
Dave
ill4na8na2
Silverado & Fullsize Pick-ups
April 7th, 2024 6:50 PM
PLATOKIDD
February 28th, 2014 3:10 PM
Seljeskogs
July 6th, 2008 4:47 PM
