Notices
Coolant Leak 1996 Suburban
Old November 25th, 2011, 5:45 PM
soulcaliph21's Avatar
Default Coolant Leak 1996 Suburban
3 days ago I had the hose to my heater core replaced because it was leaking coolant. The next day I had the two front engine mounts replaced because they broke. The same day I got the engine mounts fixed, I noticed a lot of coolant on my driveway underneath my car. After taking a look, the repair to the heater core seems to be fine. The coolant is actually leaking from somewhere I can't see right above the coolant hose attached to the bottom of the front of the block. All hoses and clamps in the coolant system are secure. Am I looking at replacing a freeze plug? Or are there any other ideas out there? Any help is appreciated.
Old November 25th, 2011, 11:44 PM
My first guess would be the water pump front seal. It usually goes when the bearings start to fail.
Old December 18th, 2011, 1:08 AM
bigava@comcast.net's Avatar
Water pump may be one problem, I have had that problem with my 97 tahoe, then after replacing the pump, some months later, I had to pull the intake manafold off and reseal it. Chevy small block offen have coolant leaks from the intake manafold.
Old February 5th, 2012, 9:48 PM
wyotechisajoke2012's Avatar
Default 1994 suburban 350 catastrophic coolant failure!
<HR style="BACKGROUND-COLOR: #000000; COLOR: #000000" SIZE=1> <!-- / icon and title --><!-- message -->
so i got stuck in about 4 feet of snow out in the middle of wyoming friday night and had to spend the night, i tried to keep it running as much as possible but i didnt have enough fuel. when i finally got it pulled out the next day it was running fine till i started to get on it. i had a leak out of my lower radiator hose. my thermostat had gone out. i replaced the thermostat, the coolant, and the hose and it ran just fine heat worked thermostat opened and everything without problems i drove it again tonight and it ran well untill i steped on it and when i looked behind me there was a large cloud of smoke, i pulled over and it was steaming (not overheated) and it was gushing my brand new coolant onto the ground. upon further inspection i noticed it was coming out from the block underneath the exhaust manifold and behind the engine mount. what could it be? freeze plug? i didnt hear a bang so i dont think im missing part of my block or anything but im completely stumped. i removed the tire and fenderwell and im in the process of taking the exhaust manifold off tomorow and trying to figure out why this is being such a pain.
Old February 6th, 2012, 10:49 PM
I'd check the water pump weep hole.
sarahlorrain
August 21st, 2015 10:05 AM
dlaroche
October 29th, 2014 7:17 PM
DrJekyll
July 27th, 2014 11:11 AM
95wt
May 30th, 2008 3:07 PM
formulalt1power
Silverado & Fullsize Pick-ups
March 14th, 2007 6:34 PM
Quick Reply: Coolant Leak 1996 Suburban
