RE: Crankshaft Position Sensor, where?
It's on the top rear of the engine, behind the intake manifold. The EGR valve is in the center, the crankshaft position sensor is on the driver's side next to it. The engine oil pressure sensor is on the passenger's side next to the the EGR valve. There's a large wire bundle splitting offto all three of those components. The connector to the CKP sensor has 3 pins, wiring colors arelight green, a yellow/black, and a dark blue/white.
You need to raise the vehicle andremove the fuel line bracket from the bellhousing stud, then from obove remove the driver's side ignition coil bolts and reposition the coilto get to the sensor. Disconnect the electrical connector. Use penetrating oilaround the sensor and allow it to soak in, then remove the CKP sensor bolt and gently twist the sensor back and forth. When it's free,remove it.
Have fun
