Cylinder six misfire and A/C hose problem in a 97 tahoe
My name is John and i drive a 97 tahoe with the 5.7 SFI engine and its 4WD... i am having a couple of problems with it. The service engine soon light is on and when i got it scanned it says its a cylinder six misfire. I have replaced the spark plugs, distributor and rotor cause i got it a couple of months ago.
It idles rough but doesnt seem to have a problem when cruising. Also the check engine light goes off after driving nonstop on the freeway for 50 or more miles.
Also after i recharged the AC, it started discharging liquid from the high port. i thought i might need a new hose assembly for that but if you think different, i would like to pick your brain.
Thanks,
John
Thanks,
John
Hi kitonga,
Welcome to the Chevy Forums.
I moved your thread to the proper section and posted to bring it to the top of the field. You were in the Welcome section, which isn't used for troubleshooting.
Welcome to the forum
I noticed you didn't list the spark plug wires... I would be suspicious of the wires for a misfire also double and triple check that you have them all in the right firing order.
As for the discharging at the port, the schrader valve is probably stuck or bent
snowman4839
January 17th, 2013 10:45 AM
For Sale: 20" Enkei Deep Six Wheels
SYEARY
May 12th, 2010 4:36 PM
