DEAD BATTERY
DEAD BATTERY
Noticed in ZX's "what to do different" post that addkev & jasonw75 both mentioned a dead battery issue. The same thing happened to me last weekend. Had radio on w/ key off and since it didn't shutoff, I know it was less than ten minutes. When I tried to start, all that was there was solenoid click. Jasonw75 mentioned that there should be a shutdown feature to prevent this. I thought there was because once I left dome lite on and it was off the next morning and the battery was OK.
Anyone else experiencing this ?
RE: DEAD BATTERY
The feature that you guys are speaking of is called; "Battery Run-down Protection", it was on the 2002 Trailblazer and it is on the 07 Tahoe and basically every GM product for the past several years.
What is does is; shut off the interior lighting if it is left on (or a door is left ajar) for 10-20 minutes depending on the vehicle, that is it.
If your battery is dying in less than 10 minutes then you need to have it checked out by the service department.
Also bear in mind that if the electrical system in these Tahoe’s is energized it is powering up to 24 different (power hungry) modules along with anything else that you have running, the bottom line is that the battery cannot be expected to run accessories for nearly as long as older vehicles.
RE: DEAD BATTERY
Dave:
Way back a long time ago, I asked how to add a second battery?? I asked my service department to figure it out also, they said I wasn't able to do it until the "camper package" came out on the new hoes... Is this doable now? What parts will I need? My battery doesn't die in 10 minutes, but it does in 15 every time. You can see on the build sheet you sent me that I took it in and no problems were found with my charging/battery/electrical system.
Jason
Jason
RE: DEAD BATTERY
Installing dual batteries is the easiest thing in the world, there currently isn’t a kit for the Tahoe but the hard part (aux bat tray) is already there. Now it's just a matter of dropping the battery in and wiring it together.
You’ll need the hold down clamp (just like the factory battery already has) and then you’ll need the black and red battery cables, swedge on some end clamps and then just wire the system + to + and – to - .
Make sure that your second battery is the same part number as the stock battery or replace both batteries.
RE: DEAD BATTERY
ORIGINAL: ZX1100F1
