Need to ask how to remove the lift gate inside panel to install rear camera...
Old November 25th, 2008, 8:17 AM
guvner's Avatar
Default Need to ask how to remove the lift gate inside panel to install rear camera...
I asked before but it probably got lost on the other things I was asking at the same time. Just want to know if anyone has pulled the inside panel off and what is the safe way to do it.
Thanks.. Gary
Old November 25th, 2008, 8:44 AM
genestoy's Avatar
Default RE: Need to ask how to remove the lift gate inside panel to install rear camera...
I did a complete "how to" some time back when I installed my Kenwood rear camera. Here is a link to the document with pics that I did at that time, hope that helps - http://home.earthlink.net/%7Egenesto...ra_install.doc
Old November 25th, 2008, 6:05 PM
d1nonly34's Avatar
sounds like a good write up. basically the lid is held in with clips. There are only two torx screws you need to remove and 2 push clips that you need to remove behind the glass. After that just tug and remove.
Old January 5th, 2013, 12:29 PM
Coheed's Avatar
i have a camera mounted near my hitch right now, and its not staying put and thinking of moving it...should be fairly easy to relocate the camera thanks for a great write up
Old April 7th, 2014, 10:02 AM
hurnik's Avatar
Does anyone have a copy of this write up they could email to me?
I'm in the same boat. 2005 Chevy Equinox LT and want to put a rear camera in the system.
Doesn't look like the original server link is active anymore. Here's hoping someone has a copy of it somewhere.
--Kevin
Old April 7th, 2014, 10:24 AM
Did you try an email to genestoy?
Old April 8th, 2014, 9:08 AM
hurnik's Avatar
PM or email? Profile says last login was a year ago.
But I'll try email route and hope they enabled the option.
--Kevin
RJK
August 2nd, 2019 5:50 PM
TomS209
July 23rd, 2015 12:22 PM
John789
Equinox
December 7th, 2010 3:05 PM
56brew
April 15th, 2008 8:20 AM
dadztoy
Silverado & Fullsize Pick-ups
January 28th, 2008 1:54 PM
Quick Reply: Need to ask how to remove the lift gate inside panel to install rear camera...
