Disabling OnStar
Old February 12th, 2010, 9:17 AM
amaniulmer4830's Avatar
Default Disabling OnStar
How do you disable the onstar system in a 09 and 2010 Chevy Tahoe/Sububan?
Old February 12th, 2010, 2:28 PM
vester's Avatar
You need to cover the dash, roof and rearview mirror with tinfoil
Seriously though, just unplug the OnStar module. I believe it is below the radio on the NBS SUVs.
Old February 13th, 2010, 12:40 PM
Welcome to the forum.
Old February 14th, 2010, 11:29 AM
TMW597's Avatar
Pull off the trim piece around the radio, take off the power port panel, then the HVAC panel (4 screws). The OnStar module will be right in front of you at the bottom. Use a long screw driver to pull back clip on the left side of the module, then slide the module towards you. There should be plenty of slack on the cables. If you unplug the OnStar module you won't be able to use your Bluetooth features.
Old February 15th, 2010, 9:33 PM
Hardin Thicke's Avatar
Alright, I can't resist asking. Why do you want to disable the OnStar? I assume it's not in active use.
Old February 16th, 2010, 8:39 PM
Maybe like that guy several years ago who didn't want his wife finding him.
Old February 17th, 2010, 7:24 AM
I don't like the fact that at any time they like onstar can shut off my truck.
Old February 17th, 2010, 7:41 AM
SabrToothSqrl's Avatar
Default really
Really? so your saying if I was designing a system to prevent a Tahoe from being stolen, I wouldn't have thought to burry it way down deep in the vehicle to prevent this?
Or can I go to any lot, pull the onstar, and drive off?
I would hope GM would plan better than that...
In any case, I'd love to be able to remotely shut down my vehicle, however I'm not going to pay monthly for it... if it's stolen, I dont want it back, just cut me a check and be done with it.
Old February 18th, 2010, 7:27 AM
I often wonder if GM surreptitiously collects driver and vehicle data using OnStar regardless of whether it's on an active subscription or not? Personally, I could care less. But the data could be used for all kinds of benign research up to getting service data to use against the owner in the instance of a major repair claim.
Old April 8th, 2010, 9:42 AM
uberbilly's Avatar
Do you know if it is located in the same location on Acadia?
Quick Reply: Disabling OnStar
