door will not close
Old February 26th, 2007, 1:08 AM
tjmedford's Avatar
Default door will not close
I need help. i was closing the door on my 2000 tahoe but it just hits the post but will not even come close to closing. It appears the "C" part in the door is turned and it doesn't marry up to the post on the door frame. It gets worse. I tried screwdrivers and anything else to get it to turn. Nothing. So I go to the passenger door and look at that one. Sure enough I got that one not to close either. I just flipped up the "C" or "U" part on the door and it will not return to it's normal position. I am sure there is a way around this, but I cannot figure it out. Tying the doors closed with rope isn't cutting it here in the snow. Your help is appreciated.
Old February 26th, 2007, 1:27 AM
Default RE: door will not close
Try pulling on either the inside or outside handle like you were trying to open the door (to release the latch) and at the same time, move the latch to the open position. Then release the handle. You should be able to close the door.
Old February 26th, 2007, 3:41 AM
Sam
Sam's Avatar
What 73 said....
-Sam
Old February 26th, 2007, 9:35 PM
tahoe07's Avatar
Did that to my 93 Grand Prix not too long ago. I had to use the inside handle and rotated it at same time.
badOHtenTAHOE
December 15th, 2014 7:21 AM
buddylugnut
Traverse
11
January 5th, 2012 2:52 PM
07Silveradooo
Silverado & Fullsize Pick-ups
December 15th, 2011 7:30 PM
TPeezy
December 24th, 2006 11:03 PM
NJGTP
October 3rd, 2005 9:52 PM
Quick Reply: door will not close
