DTC Code B1001
DTC Code B1001
After programming my BCM to indicate I now have the Navigation Radio installed in my 2009 Burb, the Airbag light appeared on my cluster.
I looked up the details and it says this can occur if the BCM has a different VIN number then what the SDM module has. This is not the case. I think since programming the BMC it lost the SDM ID's.
Here are my questions
1. Can execute the LEARN SDM ID's into BCM with just the TECH2 or do I need to use TIS2WEB
2. Will I be required to do a VTD relearn procedure also and can this be done with just the TECH2 or do I need to use TIS2WEB
3. Are there any gotcha's in doing the VTD relearn procedures that I should know about. I don't want my truck to be stranded an not able to start when I'm done.
Thanks
Thanks
