Rough idle 4 valves firing 99' k1500
Old April 18th, 2015, 12:09 AM
Moaky84's Avatar
Default Rough idle 4 valves firing 99' k1500
P0300 random misfire. i installed the lower intake gasket and got a p1345 timing off. I brought it to the shop to set the cam retard with a scanner. Now I'm getting the random misfire p0300. 1,3,4,8, are getting fuel to the injectors. They are firing but when I disconnect it doesn't make a difference to the rough idle. What would cause all four injectors to stop getting fuel. Electrical? How can I find it/fix it? Or maybe something with the spider injector not working. I was going the take the upper I take cover off the inspect the injectors. Any ideas?
Last edited by Moaky84; April 18th, 2015 at 10:38 PM. Reason: Misinformed about what wasn't working
Old April 19th, 2015, 11:33 PM
Moaky84's Avatar
I was able to diagnose by finding www.easyautodiagnotics.com the spark was at all 8 plugs and distributor cap. The whole spider fuel injector was shot mainly the fuel pressure regulator. I found out the fuel pressure regulator goes out often in these trucks. It was all charred black I replaced the assembly with the mti conversion kit and it fired up without any hesitation.
Old April 20th, 2015, 8:29 AM
Thanks for reporting back your solution. Makes the forum work as it seems to be a common problem and will help someone else in the future.
macmommy
April 22nd, 2020 1:23 PM
maurizzi
September 19th, 2014 3:43 PM
Sethyates72
February 1st, 2014 7:53 AM
VOLTAGExDT
May 13th, 2011 1:13 AM
pistonpoweredrx7
Engine Building & Overhauling
October 9th, 2006 7:10 PM
Quick Reply: Rough idle 4 valves firing 99' k1500
