Gas Mileage E85 Then Reg Gas 07 LT
Old September 9th, 2008, 6:59 PM
norrislaketn's Avatar
Default Gas Mileage E85 Then Reg Gas 07 LT
I put a full tank of E85 and watched my mileage go from 18 to 13 mpg. I switched back to regulat 87 gas about 20 tanks ago and still can not get it back from 13.5 mpg. Any thoughts? It's a 07 LT 4 wheel drive and run it in 2 wheel most of the time not auto position.
Old September 9th, 2008, 8:42 PM
Big D's Avatar
Default RE: Gas Mileage E85 Then Reg Gas 07 LT
reset your mpg setting.....also you can fill up tank and reset trip meter divi up by gallons needed to refill next time you get more gas...not scientific but it works
Old September 10th, 2008, 3:41 PM
Thanks for the reply, I am dividing the miles driven by the gallons at fill up as the one on the dash is off by 1.2 mpg consistantly.
Will disconnecting the battery for a period of time reset the onboard computer?
Old September 10th, 2008, 5:05 PM
Mkae sure your comparing apples to apples, use the gallons used setting in the DIC to do the calculations and I have found them to be pretty close, if you use the amount you filled up with whch can be over a gallon more because you fill up the neck, try only filling up to when the pump shuts off and don't give it that extra neck fill.
I always reset my trip, gallons used and average economyat each fill up....
I have never tried the E85 since I hear it is so poor on the MPG for the cost....
Old October 4th, 2008, 9:51 PM
SabrToothSqrl's Avatar
E85 is a crock... more $ for less MPG? where do I sign up?!
Old September 21st, 2009, 8:31 PM
Tried E85 1 more time, now I have to clean the injectores due to bad tank full of "stuff" causing idle issues.
Old September 22nd, 2009, 10:19 AM
Default E85
won't the dealer fix it? 5 year 60,000?
ledoux54
Silverado & Fullsize Pick-ups
September 13th, 2015 8:45 AM
NoMad7700
Express & G-Series Vans
May 17th, 2015 9:43 AM
Scotiapilot
January 29th, 2015 10:41 PM
whitefish
Sonic (Aveo)
November 3rd, 2009 9:46 AM
brenande
January 27th, 2008 12:40 AM
Quick Reply: Gas Mileage E85 Then Reg Gas 07 LT
