GM ESI techline service manuals on DVD
I found a torrent for this and downloaded the 4.3gig file with LimeWire, burned the ISO file to a DVD, I haven't completed the install yet but was wondering if anyone else has...
Looks like its only current to 2005 but looks informative
google GM ESI techline
Electronic Service Information
I got it running, its basically the factory shop manual but covers a wider range of vehicles and years but from what I could tell not the level of detail that a specific manual does.
I also tells you the expected time to complete a particular repair.
has mechanical specs bore , stroke etc...
fastener tightening specs....
exploded view of engine and components
FIGURE Intake Manifold/Upper Engine(c)
(1) Engine Sight Shield - 4.8/5.3 L
(2) Engine Sight Shield - Right Side 6.0 L
(3) Engine Sight Shield Bolt
(4) Engine Sight Shield - Center 6.0 L
(5) Engine Sight Shield - Left Side 6.0 L
(6) Engine Sight Shield Bracket Bolt
(7) Engine Sight Shield Bracket
(8) Fuel Rail Stop Bracket
(9) Fuel Rail Stop Bracket Bolt
(10) Fuel Rail - with Injectors
(11) Intake Manifold Gasket
(12) Manifold Absolute Pressure (MAP) Sensor
(13) Intake Manifold
(14) Throttle Body Gasket
(15) Throttle Cable Bracket
(16) Throttle Cable Bracket Bolt
(17) Intake Manifold Bolt
(18) Throttle Body
(19) Throttle Body Nut
(20) Valley Cover Gasket
(21) Valley Cover
(22) Valley Cover Bolt
(23) Knock Sensor Oil Seal
(24) Knock Sensor
(25) Knock Sensor Wire Harness
(26) Engine Coolant Air Bleed Pipe
(27) Engine Coolant Air Bleed Pipe Hose
(28) Engine Coolant Air Bleed Pipe Bolt
(29) Engine Coolant Air Bleed Pipe/Cover Gasket
(30) Engine Coolant Air Bleed Pipe Cover
(31) Engine Coolant Air Bleed Pipe/Cover Bolt
(32) Fuel Rail Bolt
(18) Throttle Body
(21) Valley Cover
(24) Knock Sensor
(32) Fuel Rail Bolt
printboy63
Silverado & Fullsize Pick-ups
10
August 13th, 2013 4:46 PM
exten
January 30th, 2013 10:41 AM
Matco54
April 29th, 2007 11:36 PM
