Welcome to Chevrolet Forum - Chevy Enthusiasts Forums
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Tahoe & SuburbanThe power, space, and brutal towing ability make the Tahoe and its longer sibling, the Suburban, arguably the best full size SUV's on the market today.
Hey everyone. I have a 2003 Tahoe Z71. My heated seats (both driver and passenger) aren't working right. They both turn on, and after about 30 seconds, turn off. Unlike another recent post, there is no clicking, just a power down.
Then if you turn them back on, they only stay on for about 15 seconds. Each subsquent time, they stay on a shorter and shorter time.
Tried changing the fuse, but still the same result.
Thoughts?? Thanks in advance!
Register today for free or log-in if already registered to remove this ad!
Did you get your problem fixed? Does anyone have any suggestions or advice to this problem? I now have the same problem. Any help is greatly appreciated.
__________________
2003 Silverado 1500 HD
2003 GMC Yukon Denali
2000 Pontiac Grand Prix GT - For Sale
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Driver and passenger heated seats inoperative or shut off in 30 seconds. There will be DTCs B2435, B2440, B3606 and/or B1825 set in the Drivers Seat Module. The adjustable pedal position sensor, seat recliner position sensor and both heat seat thermistors share the same 5 volt reference internal to the Drivers Seat Module. A fault in any of these components/circuits can make the heated seats inoperative or shut off in 30 seconds, as well as, the seat recliner and/or adjustment pedals may move in short increments when operated. A fault in heated seats, adjustable pedal or seat recliner will affect BOTH heated seats.
Note:: Even if the vehicle is not equipped with adjustable pedals DTC B3606 still may set.
Recommendation/Instructions:
To help isolate the area of concern use the Tech 2 and go to "Sensor Data" in the Drivers Seat Module. Monitor the following parameters for being out of range:
Recline Position- Normal range .39V-4.58V
Pedal Position (if equipped) - Normal range .39V-4.58V
Psgr. Seat Heat Sensor- Normal range 1V-4V
Drvr. Seat Heat Sensor- Normal range 1V-4V
If a parameter is found to be out of range inspect circuits for any opens, shorts to ground, or voltage. If none found replace the suspect component.
Please be aware of the following common areas of concern:
The adjustable pedal position sensor internally shorted pulling the 5 volt reference low. Disconnect the adjustable pedal position sensor and see if the heated seats start working correctly, if so replace.
Note Important:: The APP (Accelerator Pedal Position) sensor is NOT the adjustable pedal position sensor. Make sure the correct sensor, adjustable pedal position sensor, is disconnected.
The seat recliner position sensor internally shorted pulling the 5 volt reference low. Disconnect the recliner position sensor and see if heated seats start working correctly, if so replace.
An open in either heated seat thermistor circuits (signal or low reference). The most common is the passenger thermistor where it passes through seat connector C305 pin "L" or "K" or C399 pins "R" or "G".
A chaff to ground on either heated seat thermistor signal circuits. The most common is circuit 5475 black/red or dark blue shorted to ground in the passenger seat near the buckle.
Note Important:: The heated seat thermistors act differently to "OPENS and SHORTS" than the adjustable pedal position sensor and seat recliner position sensor. The adjustable pedals and seat recliner sensors can be disconnected for testing of the heated seats. Where as the heated seat thermistor circuit must be working correctly before EITHER heated seat will operate. Disconnecting one thermistor, which may have a concern will not allow the opposite heated seat to work correctly, BOTH side must be operational before EITHER heated seat will operate.
Clearing DTCs
If DTCs will not clear when using the Tech 2 after a repair has been made, try operating the device in which the repair was made. Example, if a repair was made to the passenger heated seat thermistor circuit, the DTCs may not clear unless the passenger heated seat is operated.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a ""do-it-yourselfer"". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
Thanks for the info, however I am somewhat confused with this statement:
Is there two different adjustable pedal position sensor?
__________________
adjustable pedal position sensor senses the in and out position of both brake and accelerator pedals when setting the pedals for comfort
accelerator pedal position sensor senses the position of the accelerator pedal as your foot moves it to accelerate or decelerate regardless of where your pedals are adjusted for ergonomics
