heated windshild washer fluid system
heated windshield washer fluid system can it be added aftermarket with oe switches on dash, if so what are the part # ?
RE: heated windshild washer fluid system
Yes, it can, this is one of the few electrical options that is not bus'd thru GMLAN.
The switch is a simple device with 4 wires
Black wire - Switch Ground
Light Green wire - Signal
Dark Blue/White wire - Heater Element Ground
Purple/White wire - Interior Lighting Control
Run the appropriate wires between the OEM switch and aftermarket heater element or you can even purchase the OEM solvent tank and heater and wire harness.
I can mail, email or fax a system schematic to you if needed.
croberts
May 7th, 2011 4:31 AM
