High Idle/Surge 2007 Burb
Got good advice from you guys on my last problem. So here I go again, this time with a surging issue at idle and drive. I had an extended crank last time and changed two leaky injectors and that cured that issue. The engine light is on and the code points toward a leak in EVAP system. Changed gas cap checked hoses..light still on. I curerently run E-85 fuel. Any suggestions where to start with this surging issue? Thanks again!!
