High Oil Pressure !!! help me
Hi everyone,
My name is Rafael this is my first post in a forum, so excuse me for any mistakes.
I live in Brazil, tired of our national vehicles with 1.0L 60hp i bought a 2001 Chevy Suburban 1500 LT Autoride by a equivalent 16.900 bucks. I Really loved the car the sound of V8 engine is amazing, is like i could smash any car in the streets.
But ariived the first oil change and the only Filter that i have founded is FRAM PH13, i used the Mobil 5-30. I don't remember if in the day of the swap the oil pressure was normal, but a few months ago i noticed taht when i started the engine the pressure goes to 50-55psi and when i speed up all the the measurer arrive to the end, marking 60-80psi.
And sometimes, when i turn on the engine the needle keep jumping quickly between 45 and 60psi.
Now i don't know if the Filter rised up the pressure (i think he is to small than pf46 or pf61), or the pressure increased by other reason OR the pressure oil sensor is indicating wrong information by this needle jumps.
Please guys help me, here in Brazil has not people that know a lot about these imported cars.
Since yet appreciate your attention.
You can visit AutoZone | Auto Parts & Accessories | Repair Guides & More enter the vehicle information, and it will show you the correct filter to use.
Hi everyone,
You may want to pull the oil pressure sensor and screen to clean and inspect, generally the screen being dirty will cause low oil pressure, but it is something to eliminate. Check the oil level, too much oil can cause the higher reading, and as suggested above, consider checking it externally.
You might also check the electrical connection to the sending unit it could be a poor connection.
Welcome to the forum,
What is this 'screen' ?? The sensor stay behind the engine block right ?
Are you telling me to remove the sensor and clean him up ?? Where is this screen ??
How can i clean the sensor ?
Sorry, my english is not so good.
If I'm not mistaken when i change the oil I put 5 Liters, I ever check the dipstick and the oil never stayed in over levels.
I will clean the oil pressure sensor. I think is he, because these needle jumps is very strange.
OBS : I spoke wrong, my oil filter is ACDelco PF46E not FRAM PH13.
ty
ty
ty
Ty
